Can you run an 02 sensor in each manifold and have them hooked up to the same single wire? I figure if it is possible this could be a little extra help if one cylinder or a bank of cylinders was running lean or rich then at least the 02 sensor could see it no matter which bank it is on. Does this make sense to anyone?
