I say go for it! Even though I have no idea what you are up against.
I just want to see what you get into!
Cool, thanks. I'll give it a try, but probably wait until this summer.The lower steal pan is only sealed with rtv from the factory, there is no gasket. And you can remove it pretty easily. I remove the crossmember below it. Also some of the front bolts are tricky to get to, a swivel socket helps.
It's pretty much fine during normal driving, but while towing my RV trailer it pops codes pretty much every time it has to downshift going up a hill. That puts it into limp mode which means I have to pull over and clear the codes. The downshifts during those conditions are pretty harsh too.Just looked up that code and the wording sounds familiar. It is possible that I've gotten that code.What code? P0734? If so it's trans time.
Yes, when in 5th and it downshifts to 4th under hard throttle if the trans slips it'll kick this code. Once it does it'll do it easier and easier until 4th wont hold a shift.Just looked up that code and the wording sounds familiar. It is possible that I've gotten that code.
Guess I'll have to keep an eye out for it.
Yup, that sounds familiar too. crap.Yes, when in 5th and it downshifts to 4th under hard throttle if the trans slips it'll kick this code. Once it does it'll do it easier and easier until 4th wont hold a shift.
Now that you mention it, I did notice that occasionally the dash indicator doesn't show what gear it's in. Are you talking about the plug on the outside of the transmission?Now the p0708, check the wiring harness on the trans under the truck. Does it have trans fluid in the plug? Does the shift indicator show what gear its in while it's acting up?
I do have the 5th gear lockout. Honestly, I forgot to ever try it.
Yup. I put it into tow haul, but I never remember to lockout 5th gear when going up a steep hill. Hopefully by doing that I can maybe keep this transmission running a little longer. That is the only time I ever have issues.Press and hold for 5 seconds on tow haul?
Yes. When it starts leaking trans fluid, it will short out the nsbu switch and cause some weird issues.Yup, that sounds familiar too. crap.
