'03 tahoe diagrams
possum70
Mebane, NC
Are the '03 Tahoe wiring diagrams the same as '05? I found the '05s.
possum
Most likely they are the same, or close enough to accomplish what you need.
They will be pretty much identical.
That said, I can get you whatever 03 Tahoe diagrams you need, just PM me.
Also, in addition to the PM I sent you, you might also want to check this page out... It'll help you a lot with your engine swapping endeavours!
http://www.lt1swap.com/2004vortec_pcm.htm
Also check out our Engine Bay forum. There are a number of guys who have done the 5.3L swap with very detailed build threads in there you can follow.
