Hey y'all -- i feel stupid asking this question, but I've never done brake lines and don't want to mess it up.
I have a mix of flexible, braided lines and hard lines coming from the master cylinder to the proportioning valve and then from the proportioning valve back to the ABS module. The lines from master cylinder -> proportioning valve look great.
The lines from proportioning valve -> ABS module don't look so great where they run along the frame. Should I replace these with entirely hard lines? I don't see anywhere that has an option with braided + hard line combo. I checked rockauto, etc
Attached pictures in case I'm not explaining well. Truck is a 2004 GMC Sierra Denali w/Quadrasteer, but I'm pretty sure the Quadrasteer part only makes a difference on the brake lines at the rear axle
