rdohara
I have a 05 Chevy Crew cab Silverado LT 2WD Charcoal Grey paint with Grey cloth interior. It has the 6.6 Duramax diesel and Allison trans. It came stock with the tow package CD player and XM satellite radio. I am the original owner and it has 97,300 miles on it and gets 17-20mpg. I have used Red Line Synthetic oil in the Motor trans and rear axle starting at 6,000 miles. The engine puts out 523hp and 917 ft/tq and runs and drives like it was new. What I have done to the motor is Banks Big Hoss® Bundle with IQ computer, intercooler, larger boost tubes, ram air, 20% injectors and it also has EFI Live. It also has a Fleece Cheetah turbo, 4" Turbo down Pipe, Banks 4" Exhaust with Cat Delete, BD Manifold, LBZ MP, RDL/Pro Fab Up Pipes, PVC reroute kit, EGR Removed (EFI Live for EGR Delete), Custom 3” Y-bridge Intake pipe to match intercooler pipe, Fluidamper, Custom aluminum coolant recovery box and lots more. The frame has been fully boxed front to back with .120” steel plate. It runs on 37” with Walker Evens 17” rims. The suspension is a CST 7” kit that has been heavily custom modified. It has custom fabricated spindles, full engine cage and bed cage. It is strapped at 13” of travel in the front and 17” of travel in the rear. It has duel King 2.5 shocks up front with 2.0 King bump stops and the rear has King 3.0 shocks with 2.5 King bump stops. It has a locker in the rear axle with 4.63 gears and a cromoly axle truss. It also has a link arm that runs off the top of the Axle to the middle of the frame to control wheel hop. The stock rear fenders have been flared out 2” and the front bumper is a ½ ton bumper that has been raised up 2” for tire clearance. The trans is a built ATS Allison trans with their 5 disk torque converter. The rear axle and trans both use the Mag-Hytec cover and pan. The drive shaft is a custom made cromoly 2 piece shafts that use a urethane trophy truck center support bearing. I have about $80k into this truck and there is lots more done to this truck to list it must been seen to truly appreciate it. I am asking $43,000obo and will consider trades if you have something that I like. [email protected]
