Needing help from someone who’s built a 14b before, my buddy had an ‘05 Ford axle built by a mutual friend. We were looking at it tonight it’s installed in the E350 but has not been driven and the pinion has a small amount of up/down play at the yoke. This is not in addition to the gear play, from the reading and searching I did on here and some ford forums I’m led to believe it should not have any play.
Is this correct? If it is should we pop the axles out and check for rotational drag and if none just torque the pinion nut, or should he obtain another crush sleeve and start over in that department?
