GingerPowder_1
Newbie
I'm starting to rebuild my 1979 K5 that had caught on fire. I'm 1 ton swapping it. My question is how to mount this 05+ 14 bolt ff rear end to my blazer using leaf springs. The stock spring perches on the 1 ton axle is roughly 49 inches apart. And the distance on the leaf springs that are on the k5 now are roughly 43 inches. So obviously I have to make something wider. I guess my main concern/question is if I remover the perches on the newer 1 ton and weld them on the 43 inch center to match what's on the k5 now. Is that a common thing to do.
Truck now has
corporate 10 bolt 8 lug front
Corporate 14 bolt SF
I'm swapping in
05+ GM 14 bolt FF
05+ Ford dana 60
Truck now has
I'm swapping in
05+ GM 14 bolt FF
05+ Ford dana 60
