socoinslo
So as the title implies, Im going to swap a LQ9 in my 89 suburban. I want to make it CA smog legal which makes it a little more difficult. Probably most ppl on here dont usually deal with smog issues, but Ill post here anyways.
what I need to do s get the Evap system from the engine donor vehicle (2006 GMC Sierra 1500 Denali AWD) installed and properly functioning in my suburban. To my knowledge, the main components to the evap system are:
Charcoal canister
canister vent valve
Purge solenoid/valve
fuel tank Vent solenoid/valve
fuel tank pressure sensor
Right now, I think that the easiest way for me to get all these components in my truck is to swap my fuel tank for a 99 suburban or Tahoe fuel tank. This tank will have provisions for the vent solenoid and will accept the newer style sending unit which includes the tank pressure sensor. Looking at pictures of the 99 tank though I am a little confused about what the third hole in the tank is for (picture below) one for the sending unit, one for the vent valve, and ?
Charcoal canister
canister vent valve
. I just don't want to go through all the trouble of swapping my fuel pump in my old tank and plumbing my fuel lines to it, and then not passing the BAR inspection. What I ended up doing is just cutting the pieces I needed off the newer style tank and welding them to the older tank, now I can use the newer style sending unit and I have the mounts for the vent valves. I am VERY open to other suggestions though... that is why I started this thread
