jones
Sounds like a good deal for $150.What are your opinions?Purchase includes block and rotating assembly only.Cross hatching still visible in the cylinders.
This is my first engine build.I've been intimidated by it for to long and have decided to jump into it just like every other aspect of my truck and friends trucks.I admit to being completely clueless about it.That's why I'm enlisting the help of the pros on the board.
Sounds like I'll be needing a cam/lifter kit,timing chain,heads(off my current engine)as well as the other accessories.The truck is used mostly as a work horse and occasionally drift busting and mud holes that I happen across.Economy isn't to high on the list of priorities,but would like to see at least 12mpg with sensible driving.
What should I be looking at for a cam?Will my stock heads work or will I be wasting my time w/o some form of headwork? $500 max. budget on this so no aftermarket heads or anything like that right now.Should I use my performer intake or the stock one?How does a .060 350 compare to a 400 as far as tq/hp?
What can I do with my OEM dist.for upgrades?Thanks in advance.I'll update as I get more info.
