trevmountain
So I talked to SMI (Sean Murphy Induction) regarding the custom tuning job they are about to do on my old Edelbrock Q jet and we got to talking about fuel pressure, fuel lines ect. He is claiming that for my new 500+ hp motor I may need to get 1/2" AN fuel lines including the pickup line in my tank all the way to my carb. As well he recommends a fuel pressure regulator to keep my pressure at about 5 psi.
Just wondering what the consensus is on this? If so what is the best way to go about doing this. Should I piggy back larger hose to my existing stock steel lines? Never been inside one of these tanks so not sure what's involved in replacing the pickup line.
Finally if all of this needs to happen I would assume I would need a higher volume Mechanical fuel pump. Right now just running stock.
Would love some recommendations for parts. Including what style and brand of fuel lines, fuel pump, fuel regulator and gauge, and necessary fittings.
Oh and this is regarding my big block K30 long bed pickup.
