1/2 ton axles and 4" Skyjacker lift, Rancho RS9000 shocks
dodgedude99
burbia of illinois
1/2 ton axles and 4\" Skyjacker lift, Rancho RS9000 shocks
i started my 3/4 ton swap this weekend so i have so extra parts to get rid of.
so far i have
front 10 bolt axle with a Skyjacker steering arm and Superwinch hubs, no calipers ortie rod (i need that for my crossover).
rear 12 bolt axle, it seems to maybe be a 4.10 but when i finally get it off i will verify it and the front ratio.
front 4" Skyjacker springs they need new bushings.
also i had taken off a set of rancho adjustable shocks, so im assuming they are rs9000s.
and finally a mismatched set of 33"s and aluminum 80's style rims.
2 Sport King A/T's which look like new and 2 that seem to be like a house brand or something and have 1/2-3/4 life still in them.
$500 for all or make an offer on what you want.
im hoping i dont have to have this stuff laying around in the yard to long.
prefer pickup from 60453 or will ship if your willing to pay.
Re: 1/2 ton axles and 4\" Skyjacker lift, Rancho RS9000 shocks
no reasonable refused, i dont want to go another year with having a set of axles in the yard and a set of tires, i already have 3 sets of tires in the basement.
what is the gear ratio on the axles? You might get more bites if it was 4.10's or higher... /forums/images/graemlins/waytogo.gif
do you have the 4" springs in the rear , or blocks?
if you have the 4" springs , how much ?
the front i found out was a 3.42, the rear axle is still on the truck, so i wont verify that ratio till i pull the axle next week and pop the cover so i dont have to drain the fluid totally out.
its just front springs, there rear appears to be a mess of overloads and extra springs with a couple of shims stacked in there for good luck (the previous owner did that not me).
$75 for the springs.
ill take thoses springs shipping to 17028 Pa
Gixxer i pm'ed you.
on the front axle, since it has the worthless 3.42 gears, im probaly going to part it out, and whatever doesnt sell gets to be recycled steel.
it does have Superwinch lockouts.
make offers, im tired of my yard looking like a Pick n Pull.
