Aegis43
Registered Member
Looking for help from you experienced guys, as I have very, very little.
I have a 385" stroker sbc with AFR 195 heads in my Blazer. It's got a "medium" performance Lunati hydraulic roller (225/229 @ .050, .592/.592 and 112 LSA) which I know is wrong for this truck. It was originally in my 2nd gen Camaro, but I went to a big block. The 5.7 in my Blazer was tired, I had the engine from the Camaro in my garage, so it got swapped in. Currently I have mismatched 1.625" round tube headers and 2" exhaust, which I believe is significantly choking exhaust flow. As many would know, AFR 195 heads have square-ish exhaust ports which are larger than the primary tubes on my headers. Fortunately, the flanges on my Hedman's are thick and large enough that I don't have an exhaust leak.
My question is if any of you guys have 1.75" square port headers on your K5s? If so, what brand? Thank you in advance.
