1" body lift/ body mounts
suntadz
bay area, ca
I was wondering how difficult replacing all my body mounts and doing a 1" body lift would be on a stepside. Wasnt sure if the bed is raised with a body lift and if it would work on a stepside. Ive seen some cracked bushings under there and was thinking of atleast doing the mounts in urethane but was debating whether or not to do the body lift. anyone got any feedback?
imo, if you need to do bushings, it's foolish not to do a 1".. the 1" kits come with bolts, so for that alone it's good.. But i really like a 1" bl, minor shroud issue, but generally no other mods are needed... clears some space at, fuel tank, dizzy, etc...
I just did it to my K5. Hardest part was getting the old, rusty stuff off. No adverse affects (fan shroud, fuel filler, shift linkages). Ended up with about 2", since the bushings were shot. It even got rid of some of my vibrations:dunno: . Now I'm going to 38x15.50 Radial TSLs.:D
I did new bushings and 1" blocks on my 89 Burb and I got more like 1.5" cause the rubber bushings suck and had worn out. I agree that the lift kit is worth it for the bolts alone.
I did have fan shroud issues at the bottom, but it was nothing that a little creative trimming didn't cure. I left my bumpers down and the front valance fills in great, but the rear rubber piece is a little tweaked. I am going to get a new one and then adjust it to make it look better.
JUST DO IT!!!
