Anytime Man
I got everything from ORD, And when I put it all together I used Anti seize on the bolts. I got new bolts with the Body lift, But I don't think your going to get new hardwear with just new mounts.
I bought my kit from a member here a long time ago. He bought the works from ORD and yes it did come with all the hardware. The 'destructions' sorta suck...but it wasn't that hard to figure out.
I just did the Poly and 1" ORD lift. I used some Lubrethane (like a white glue that doesn't dry) on all the poly pieces both inside and top & bottom contact areas. No squeaks yet!!! Of course, it has only been one day.
My '73s rear bolts were the worst to try and get out. BOTH of them were bent into little S's.
The bolts under the rear seat had to be cut/grinded out - because of the factory weld. /forums/images/graemlins/tongue.gif
