I'm about 1/2 way through the rebuild process. Billavista's article on Pirate was a good resource. Of note, a ball joint press helps a great deal with lower kingpin seat R&R. In my case the upper nylon bushing was very worn and the kingpin was pitted and galled. The lower bearing was shot but not as badly as the upper.
As for the kingpin removal - what a pain. I purchased a long arm 7/8 hex key and still needed a 6' cheater bar. 4' would not cut it. Thank goodness this is a west coast rig and not corroded.
