I'm looking to replace the original 1/2 ton disk/drum booster + master cylinder + prop valve on my 72 blazer and I'm looking for some input. I'm planning on sticking with the original 1/2 ton running gear for the foreseeable future, just a 4" lift and 33" tires.
I was thinking that while I'm at it I might as well put a 1 ton booster and master cylinder on. Is there any benefit for doing this when I'm planning on sticking with 1/2 ton axles, etc?
I'm also looking at an adjustable prop valve from CPP so I can dial in the pressure to the rear. Can anyone make any other recommendations?
