1 ton gear ratios?
baddane1
Newbie
Hi i am new to the forums here. I am going to buy aa 1979 1-ton 4x4 to play with. My main ? is right now is what are the front and rear gear ratios? It has a 350 with a 465 trans and 14 bolt with a dana 44 in the front and i am unsure of the t case also. What normally came in these as far as the gears and the T-case?
Thanks,
MJ
WELCOME TO CK5 /forums/images/graemlins/waytogo.gif
Tcase: NP205
Front axle: Dana 60
Gear ratios: 3.73, 4.10, 4.56 - with a 465, I would say probably 4.10, but it could be any of those.
Gear ratio will depend on how the truck was ordered. 3.73, 4.10 and 4.56 were all options.
If that truck does have a Dana 44 in the front, someone robbed the best part out of it. I've seen alot of 1 tons get the Dana 60 taken out and a Dana 44 put back in its place to be resold.
