1 ton parts
udy2554
Naples, N.Y.
I'm kinda new to this. I have an 88 Blazer with a lot of 1 ton parts on it, but I don't know what they are worth. These parts will go up for sale, but are still attached to the truck. The only parts I want to keep are: motor, seats, and the hood. Axles and drive train are for sale, maybe as a rolling chassis. Right now the tires and rims are spoken for, but that may change.
The drive train is: Dodge dana 60, 4.10's with lock-rite, should be 35 spline outers, but the re-builder has screwed me and that has not been verified. Corp.14FF, 4.10's with lock-rite. New brakes all around. They may need reserfacing, truck sat for a couple years. Both axles have new seals and such, and the 60 has new king pins and bushings. SM465, 12" Luk gold series clutch with mech. linkage, 205, new drive shafts front and rear. (extreme duty).
The drive train held up to 560hp and 535ft/lbs with an idiot driving it. I've never had a problem except for the z-bar pulling free from the ball stud on the motor, but remedied that with new bushings and moving the z-bar closer to the motor about 1/4 inch.
I'll attempt to post pics, but it is time consuming on my computer and some times times out before it is done. If there is any interest, I will send some pics via e-mail. I'll do my best to answer q's as they come.
Thanks for bearing with my long-windedness,
John (udy2554)
Those axles are junk! If you give me $100 I'll come up and take them off your hands.:D
I'll get some pics in the next day or so, I have not taken the truck apart yet, but i have someone interested in the rear drive shaft, so I will remove both when the rain stops. Hopefully tues. or wed. Hope that's soon enough. I don't have a clue as to shipping prices yet, but I will look into that also!
Sorry for the delay in replying. Thanks for the input on price. I was kinda hoping for the $1000 range. With the weather the way it is, I haven't even thought of laying under the truck to look at things. The 60 is rebuilt and for the most part new, except for sitting idle in a field for a few years. New bearings and seals and such. Original ring and pinion though, with lock-rite and 4.10, new brakes complete.
The 60 is spoken for,as are the tires . What might you be looking for. Keep in mind that I've been a little busy with the heat and AC season and it may take a little time to get stuff out.
Nope!!!!!!!!!!!!!!!:laugh:Sorry, that was my first try at building a motor. Besides, it's been sitting for about four years. Probably could use new rings and bearings. I'll probably step down tuning a little and try to fuel inject it. It'll be a couple of years till I can do it though!
Denny's Driveshafts built the front shaft after being given the motor's numbers. I don't have clue one on shipping but I will look into it. I'll also get the size of the u-joint caps. The truck had 4-6 inches of lift in the front. I can't tell you exact, but that is close. It fit 38's with no rubbing. It didn't have great articulation though.Thanks for your patience.
This may sound insane..
But if the grill trim is still good, i'd liek to snag it. Need it for my 84
Here are some pics. The only ding I see is around the pass. side lights. Let me know if they are worth anything to you.
