1 ton rear driveshaft
greywolf
ST.PAUL TX USA
400/205 u joint 59.5" long this is for a 4l80e/205 in a 91 1 ton burb project.
needs joints ok
rusty ok
just the ends would ok also i can get retubed
:thumb:
Is your measurement listed from the weld to weld beads or the overall length?
I've got a Sub d-shaft removed from an '80 K20 that had a 400/205 with a slip yoke. Should be correct for you.
std way to measure is
center of cap to center of cap.
if slip in tranny or tcase install slip in to normal position wear seal rides on it normaly. then center to center cap measurement .
hope this helps . :D
needs joints ok
rusty ok
:thumb:
If you can get it retubed and just looking for 1350 fixed yoke ends I think I can find you one here.
I will see what I find this afternoon and report tonight or tomorrow morning.
I know you won't find one ready at the measurements you want so you will need to get one made.:thumb:
I have one that I cut down for a K5 with a fixed yoke NP205 (1350 at both ends)... I'm fairly sure it is too short. But I would take $75 plus shipping and I can cut off the tube to make shipping the ends easier/cheaper.
While on subject of shaft needed for greywolf, my need is a 77-87 K30 SRW std cab rear driveshaft TH400/NP205 to 14B FF, 131.5" WB, without yoke is fine, main shaft measures 57-7/8" outside-outside, joint to joint center 56-3/8", and weld to weld 52-7/8". May also come from a 1980 K20 SRW std cab rear driveshaft TH400/NP205 to 14B FF, 131.5" WB
