1 ton to 1/2 ton swap?
viperrgh2
NY
Found a 1 ton 85' crew cab pick up with 14 ff dana 60 np205 and th400. Will these bolts directly into my 84' 1/2 ton K5? Can I use my old driveshafts?
Hey man, I'm going to ease you into this since you haven't been flammed for it yet, lol. Do a search on this because it's been done countless times. They should bolt in but you're going to have to get conversion u joints to be able to use your drive shafts. If you run into any problems, we'll all be more than willing to help. Good luck and good score! :waytogo:
He'll also need to relocate the spring perches on the 14BFF won't he?
Thats what I was mostly getting at becasue I remember someone saying that but wanted to clarify.. I guess the rear end leaf mounts are in a diffrent spot in the 1 ton and I need to take off and re weld them in the correct spot?
So are you saying the perches dont have to be moved for the front?
MTChevy said:
D60 will be fine, just 1 ton 14 bolts need the perches modified
See, not to be an ass but that's where the search comes in. I wasn't sure if the 1 ton Subs were the same as the 1 ton p-ups. Hell I figured they would be the same. I knew once I started running off at the mouth, someone with some credible knowledge would chime in! :D:haha:
What about 3/4 ton 14 bolts? What's the difference in the two? I always thought you didn't need to move perches on 3/4 ton 14bff.
I'm 99% sure you dont have to on a 3/4 ton. The springs were just set wider on a 1 ton I believe. That's why the shackle flips are different too right?
Suburbans NEVER came from the factory with 1-tons
They only had the 3/4ton rears on the burbs. Couple places make new spring perches check with diy4x4 and ORD. Plus zero rates would be nice options on where you want to mount.
