uglytruk
- Joined
- Oct 24, 2004
- Posts
- 1,329
- Reaction score
- 0
The wiring on my '84 Blazer/6.2 is really hacked. The alt wasn't charging, so I brought it to the local hack Starter shop, and he said he could easily modify my "metric" 97 amp alt to a "1 wire". I said I thought they had a high cut in, and for snow plowing, the K5's primary purpose, the high cut in wouldn't be the best bet.
Nevertheless, he told me NOT to connect the plug, which was a hacked bunch of wires. So when I finally got the large bolt-on rear wire repaired, and started it up, I was right. The alt doesn't cut in until prob 1000 RPM. Then the needle dives for 15 volts. I just did it at lunch time today, but even with the hi beams, heater, wipers on full, it seems to stay in the (innacurate) charge zone.
So is the only disadvantage to the 1 wire just that it has to be revved to start charging? How does it work? There is still the two prongs where I COULD plug in. I just taped the plug over, no by-pass or jumper wires.
http://www.youtube.com/user/CORVAIRWILD
