oneofthefewbmx
Hey guys, I have a NEVER-BEEN-USED Mile Marker Hydraulic Winch 10,500 lbs.
This is the military winch used on the HMMWV H1 Hummers. Super strong!
It comes with 100' of 3/8" cable, roller fairlead, NO remote, NO hook.
I have this identical winch on my offroad truck (previously 86 chevy on rockwells and 44" boggers with a cummins, now 2000 GMC on rockwells and 44" boggers) and it is a BEAST. It has literally never let me down. I swear by this winch! It is powerful, continuous (does not overheat), only draws 2 amps (for the remote), uses the stock power steering pump (just add 2 hoses), and is even submersible (will run fine under water or mud)!!
Check out this review on 4x4review.com:
http://www.4x4review.com/Reviews/Pr...r10500lbhydraulicwinch/tabid/196/Default.aspx
I will post up some pics tomrrow when I get off work. The only pictures I have right now are from the MM Website.
Specs (from MM website)
Rated Line Pull: 4763 Kgf
Gear Train: Planetary
Gear Ratio: 6:1 (low gear) / 1:1 (high gear)
Motor: 293 CC 3.5 GPM (13.3 lit/min) @ 1500 PSI (103.4 bar)
Cable: 9.525 mm X 30.5 m (length)
Directional Control: 12V Solenoid 3 way (also available in 24V)
Valve: Integrated (max. rated flow 13.3 lit/min) draws 2 amps
Hoses: 3000 PSI (207 bar) rating. Uses size 6 JIC swivel
Drum size: 63.5 mm X 228.6 mm (long)
Bolt pattern: 254 mm X 114.3 mm (4 bolts, 3/8")
Shipping weight: 47 Kgs
PM or call/text me 254-220-6805
here are the pics from MM website, and a quick snapshot of a google search for MM hydraulic 10,500 winch...
