Found this on a B body forum but it could very well be the problem to axle bearing failure in our trucks too!
My 1990 Suburban has needed axles and bearings for awhile because of the wrong gasket installed at factory! I have been overfilling the rear diff for a couple years to lubracate axle bearings and only use the truck around town anymore. Now that I have a 12 bolt rebuilt and ready to install in place of the 10 bolt I found the article above (got a B body too) sure enough, wrong gasket!
So when you service or repair your rear axle make sure you have the correct gasket that does not cover the holes!
http://www.impalassforum.com/vBulletin/showpost.php?p=2200154&postcount=9
some of the rtv i pulled from the holes was almost 1/2" long
no wounder the threads get ripped out of the hubs.
