10 bolt axle repair bearings
snowdriver
oregon
i just installed 2 of these in my 1990 blazer,so far I like em,easy to install and like the idea behind them,and much quieter now,has anyone used these before,and do they hold up in the long run,?
Front or rear? Im assuming either for the spindle on the front, or for a worn axle shaft in the rear...
should be for the rear axle .
it puts the bearing / seal area in a different spot for worn surface on the axle shaft .
see people run them . . . . but seen problems with them . keep a eye out for oil leaks .
