I was looking for a 30 spline carrier to upgrade (so to speak) my 10 bolt and saw on Randy's website he only lists one carrier for a 8.5 10 bolt. The information on there said that his carrier will work for either 28 or 30 spline applications. I was wondering if this was true for all 10 bolt carriers? He also sells a HD 10 bolt carrier that uses different carrier bearings. It's made my Yukon and is called the EXTRA HD carrier. If I'm going to use aftermarket shafts, a lock-rite and 4.56 gears on 35's with at least 400ft/lb of torque, is there a need? It's only $23 more.
