[ QUOTE ]
There is a nut - lock washer - nut.. did you get the lockwasher out? they are sometime hard to get loose. Should come straight out.
[/ QUOTE ]
Does the washer have a bunch of small holes around its circumfrence? If so, I just need to use a punch to knock it around to get it loose? Under that is the adjusting nut? and I use the same socket as the lock nut? Sorry for all the questions, just dont want to have to tear into it again and still not know what to do. Thanks./forums/images/graemlins/waytogo.gif
