masterblazer
Registered Member
i know the obvious advantages of having a locked front end but work on a budget. what would it hurt to weld the front gears solid? as long as the lockouts were unlocked on blacktop would it be fine???
No more stress or chance of breaking shafts then paying hundreds of $$ for a locker. Steering is harder and the turning radius is increased on the trail, but I wouldn't call it "impossible".
I drove a Welded 10 bolt font end around and wheeled it, it was a little harder to steer when the hubs were locked and thats about it. To say its "Impossible" is ridiculous. If its that hard for you then go to the gym a little more often![]()
Not true IMO, the "slop" that's designed into mechanical lockers takes a lot of stress off of everything when you turn. One bit of proof is that Longfield warranties its stuff if you use a mechanical locker but won't with a spool.
