10 Bolt Front Lockrite ?
01mudslinger
GRETNA, VIRGINIA
i just pulled my rear 10 bolt out and put in a locked 12 bolt and my question is will the Lockrite that was in my rear 10 bolt go in my Front 10 bolt so i can be locked at both ends...;)
Yep no problem. I pulled the Lr out of my rear 10b and installed it in the front.
Lrs are a little noisy in the front. and i ran with one axle locked out a lot.
i have since pulled the lockrite and put in a no slip in the front. It is a lot tamer locker for the front. had no breakage problems with the lockrite in the front. But i an easy on the gas.
Thanks guys, ive completed the swap and am now locked on both ends..:D guess time will tell how how harsh it will be since im running 38s
I was able to make a 10bolt front last a while, it did really well with 35s, but I even got some wheeling time in with my 42s and it did alright... just go easy on the skinny pedal and when it starts to hop let off the gas.
gabe
