my cousin is up for a visit and he swapped out his 2.73 gears open diff to a 4.10 and posi unit in his 2wd 10bolt .
every thing he said was good and in spec but after a 10 mile test drive its HOT to the touch and its now got a bit of backlash as you turn the pinion .
any thing to be checking ? ........ now its cooling off and then we will pull the cover and check .
