10 bolt rear disc brakes
TC4x4
Michigan
Is there a kit out there to convert these too, what calipers would i have to get to do this? 15 inch wheel by the way. thanks
Wonder what their donor rotors are. Unsure if the rotor picture in the first link is representative or not, but it's a 6 lug re-drilled for 6 more.
Just FYI for the OP, the later disk calipers from Cadillacs use a thinner rotor, I believe someone found a GM pattern 6 lug rotor thin enough to work with those calipers, used on the newer trucks (88+ somewhere) that was the right thickness. Might be hard to find the post, but there should be at least one covering 14SF disk conversions that lists the rotor application.
