10 bolt ring and pinion sets-found
big dan
Arkansas
Have to replace front diff bearings and want to regear but Im cheap, looking to see whats out there for used gear sets.
I need 8.5 10 bolt and either 14 bolt gears (9.5 or 10.5). Running the 9.5 rear right now but have a ff Id be willing to swap in if someone had the gears for it. Looking for 4.88s or 5.13s, 4.56 would probably be ok too. If the gears are for 14bff I either need them to be the thick gears or I need carrier too, currently geared at 3.73.
Edit: Looks like blazinzuk is gonna have what I need so no more searching. Thanks for the help ck5:waytogo:
I have a set of thick 4.88's for a 14-bolt (10.5") in perfect condition! Re-geared due to installation of doubler. $150 shipped! Can get pics tonight if interested!
Dan I am working on getting a 14 b sf and get it geared I have 4.56s in there right now. Keep me up to date on what you find it will probably be a couple months
Really looking for something a bit cheaper but if I can find a good deal on a set for my 10 bolt front to match Id be interested. Let me keep searching a bit to see what I can come up with and Ill get back with you. Thanks.
TTT with one last edit. Found a 4.56 rear end so Im only needing 4.56 front gears for 10 bolt 8.5.
Kind of forgot about this thread but as it turns out, Im still looking for some 10 bolt 4.56 gears:doah:
