Well, I finally got my D60 home and in the garage. I will list what I have for it and then I'll ask a few questions:
D60 passenger drop king pin front end. It has Power Train hubs (Selectro type).
I was given two laser-cut spring plates (thanks Speedo)
Will be receiving Sky cross over on Saturday
Purchased loaded calipers from NAPA.
Purchased Yukon king pin kits.
Still need a 2wd gear box and u-bolts.
Questions:
1. If I get a steering gear from the same year (1990) will the power steering hoses thread right in?
2. Will the original brake hoses bolt to the D60 calipers?
3. What grade bolts should I use for the two straight bolts on the passenger spring mount?
4. Since this is my first D60 endevor, what am I missing besides 35 spline outers, locker, and high steer?
Questions:
I think we are on the same page. The piece's left edge lines up pretty much exactly with the left edge of the diff cover and is just inboard of the sping pack in your pic. It shows up as a slightly brighter rectangle in that location.
So it's just the rears?
It's just slow in there right now.
