I've always liked 12 bolts,never had much trouble with one other than stripping the yoke splines off one in my 72 K5....but many off roaders claim they are only marginally better than a 10 bolt,and the pinion and bearings are actually smaller on a 12 bolt...so it's a toss up whether it's really "beefier" & worth swapping one in--both are still 1/2 ton axles in the end...your not gaining much,if anything..(two more bolts?)..
A 8 lug SF or full floater is what I'd be swapping in,its not really any more work,and might not cost much more,many yards sell them for 300 bucks or way less if your lucky...then all you need is 8 lug outers up front and your truck will be a lot less failure prone..unless your extremely hard off road with it...then a dana 60 is nice..
