jsasada81
Newbie
WAIT! Before someone gets on me for not using the search feature...I have, and could not find my answer directly.
This newbie thanks you for your patience.
I recently purchased a 1988 Jimmy. It was used as an engineering vehicle at the airport I work at. Only 89,xxx original miles.
Here is my question. I am ready to buy a 6" BDS all spring lift. I have already purchased rims (15x10) and tires (35" BF MT's)
After spending an unhealthy amount of time on this site and seeing that I am about to spend big $$ on a quality lift, I am getting nervous that my 10 bolts (front and rear) will not hold up with 35's.
My question is this. How weak are they really? Am I going to snap an axle shaft just from riding a trail, spinning the tires a bit or climbing a small hill? I can see rock crawling or suddenly "hooking up" with hard ground and shocking the axles. What about easy trail riding, hill climbing, and some mud? I just need an honest answer with some examples of what I can and cannot get away with. I know it depends on the driver, etc. Can someone give me some real world expectations for this setup?
Thank you kindly
Thank you kindly
