10 degree shims
rcamacho
WA
I need a 10 degree down correction in the rear after installing 56" springs and 4" shackle flip. Considering getting some steel shims from DIY or ORD. Any experience running a shim this size vs. just cutting and welding the perch?
10 degrees will be pretty steep. I would just get some new perches and adjust the axle how it needs to be.
x2. Thats quite a bit of shim. Most of the places sell spring on perches are usually only $25-35
