I suspect the main reason why GM sized the alternators as they did, was simply idle output. The SI-series had pretty bad idle output numbers, which was apparently somewhat rectified with the CS-series. Even then, as already mentioned here, idle will be a problem if load is fairly high at idle. Somewhere I've seen the output charts, but it may have come with the alternator, and who knows if that was realistic.
GM was installing 80+ amp alternators on the full size cars back in the early-mid-80's, when even the most optioned out cars couldn't use anywhere near that much. The duty cycle is probably part of it, but so was the idle output.
