Been a while but in stock form which taper is the hole set to accept the TRE or DRE? I can't remember and don't feel like searching. Need to know which end is stock taper so I can order the same taper for a crossover arm.
I'm looking at purchasing this arm from WFO: https://www.wfoconcepts.com/pr/Dana-44-10-Bolt-Forged-Cross-Over-Arm-2-Tall/3163/3168/3461/3709
It asks to choose from a TRE or DRE hence the reason I don't know which to choose from as I have a stock unmodified 1104 arm. I don't want to do anything to it but get the RE that will bolt and go.
Now when you say the depth of the taper is one setting the RE deeper than the other? I want to choose one that's not so deep the boot is pinched tight.
