Hey so I have a '12 Silverado 6.2 with a 6L80. I recently had a transmission cooler line rust out and leak badly so I replaced the lines and in the process I cracked the stock transmission cooler. I replaced that with an aftermarket Hayden unit that uses just barbed hose connections because the lines I got from the parts store didn't fit properly so rather than ripping out the lines that I just installed I figured just make up some hoses and call it good. Well one of the hoses popped off the new cooler on the way home today and made a huge mess. The transmission started shifting funny, then started slipping, then slamming into gear and slipping again so I pulled over after a few miles of this and found the blown line. To get it home I had my wife bring me some tools and ATF out to where I pulled over. I bypassed the cooler by looping the lines together as the rubber line kept squeezing off the hose barbs on the cooler. I topped off the ATF which was only about 1.5qts low. I drove it home and it shifted fine.
I plan on doing a pan drop and filter change, but do you think I did lasting damage to the transmission? It's got 110k miles and I had the tranny flushed before by a Chevy dealer around 75k but the filter is still original. I'm shocked that I only lost 1.5qts. are these tranny's that sensitive to fluid level?
The rubber hose I used came with the Haydon transmission cooler and it looks like a Gates overseas rip off and is actually 11/32" not 3/8". Which being smaller makes me think it would be less likely to pop off of a 3/8" barb. The hose feels a little soft after just 60 miles on it. Anyone recommend a specific hose that's rated for transmission fluid?
