12 bolt disc brake kit
Jason4x4
Chandler, AZ
I have everything, I mean everything. it is used.
rotors, studs( you will need to enlarge the holes in your shafts), calipers ( no parking brake), I might even have a new set of pads, hardware, brackets, hoses, and if you want, the hard lines too.
Start at $150 + shipping.
I'll get pics up tomorrow.
What are the rotor applications?
How wide are those spacers between the flange and bracket?
Hi-jack: is that a fully welded bead around the tube at the housing ends?
Wow. I've seen that done to a 14FF once and the truck was a mall crawler.
when I got it, he said the rotors are front rotors, same truck, and the spacers are 5/8".
also a note, when I took the brackets off, i've haven't seen it before, but it appears they welded another plate on the inside of the bracket, so the bracket actually was sandwiched between the outer flange and the plate, I don't see it being a problem not having the inner plate, but I will get a pic tomorrow so it makes better sense.
Were the rotors mounted outboard or inboard of the shaft flanges?
