hoodride
is there such thing as a 12 bolt front axle? or is it nonexistent? Saw it on a craigslist ad, and i've only found 12 bolt rear ends
Technically someone could make one . It involves changing the tubes and welding on the knuckle ends ( called C's ) and springpads . Not to mention you would need to center the center section more to make the passenger side spring not hit the housing making driveshaft not line up right anymore ( normal fronts have a notch in the upper left of the center section where the spring sits ) .
Doubt anyone would go through the trouble
i dont know if itll be functional though wont the axle spin the wrong way
