12-bolt u-joint size
Mastiff
Tucson, AZ
I'm swapping a 14-bolt into my K5, but it previously had a 12-bolt swapped in place of the original 10-bolt... I read that the 10-bolt used 1310 u-joints, would that be the same for 12-bolt? How can I tell for sure? I want to get the correct conversion u-joint for my swap.
Well, my '90 originally came with a 10 rear, but had a 12 when I bought it. It had a conversion U-joint as the 12 has an S-33 yoke. My driveshaft itself was unaltered...and I'm guessing they did the same for yours. So, your driveshaft should have a 1310 yoke at both ends, and you'll need the 1310 to 1350 conversion joint to make your 14 bolt swap happen. Clear as mud? :D
Hmmm. Weird thing is, I myself bought a CV driveshaft for it since the 12 was installed. I ordered it over the phone, took a few measurements, etc. I don't remember any special U-joint being involved. But maybe I told him it was a 12-bolt and he put S33 on the driveshaft?
Can I look at it or caliper something and know for sure?
Yep, sure can.
First of all I will make the following comments:
- GM used different configurations over years
- you are dealing with trucks 20+ years old and therefore a good possibility that stuff has been swapped around
Most 12-bolts in factory applications I have seen used a 1310 u-joint, but just about any aftermarket yoke is available.
My '90 with factory 10-bolt axles had S44 u-joints in the rear, and of course the 1310 front. Most factory rear 10-bolts I have seen were S44, but have seen a 1350 in the fairly rare late model K5 with manual transmission.
Quickest way to narrow it down is whether the u-joints have the internal c-clip or external lock ring retaining method.
The 12 bolt should use a spicer 5-153x, the 10 bolt should use a spicer 5-3147x, and the 14 bolt should use a spicer 5-178x. ( 10 bolt to 14 bolt conversion 2-1153 Neapco or 5-3205x Spicer ), ( 12 bolt to 14 bolt conversion 3-3140 Neapco or 5-460x Spicer ), ( 12 bolt to 10 bolt conversion 3-3130 Neapco or 5-3022x Spicer ), might write this down for your records.
Super awesome reference right there! I think that info is going into my manuals.
Clay
