I'm currently running a 12-bolt behind a tired 350 but am about to swap a 375hp 383 into it and the 12 bolt is leaking from the left axle. I have shopped around and can get bearings and seals for the 12-bolt done for $550. Question is whether I should drop money into the 12-bolt or get a 14-bolt for $1K ($300 core, $650 bearings/seals) $1,200 if I need to regear. I will wheel the truck some but not hard. I mostly drive like an old lady but still have doubts about putting money into a 12-bolt with the new motor.
I may decide to do the axles/seals myself which would save $300-$400 but not sure that matters much to the question of whether I keep the 12-bolt or go to the 14 since the savings is similar (as long as I can find a 14-bolt with the right gears).
