12 bolt
pjwalters
kansas city ks.
is it worth $100.00 bucks to get a 12 bolt to replace my 10 that has a factory limited slip? Oh yeah the 12 has a mini spool also.
id do it, easy as pie putting it in and you get a little more strength, and peice of mind. I'd also treat it like the 10 bolt cause it has the spool in it so you basically even it out on strength if you know what i mean
sun desert offroad http://community.webshots.com/user/scoobydann
Might take into consideration, is it the same gear ratio? if it is, then go for it.
Keep it simple!
for $100 i would do it if it has the same gears if not then i wouldnt do it
77blazer see it at<a target="_blank" href=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</a>
Does the 12 bolt have stock axles?If they are stock I dont think they will last long with the spool.
"I AM THE HILIFT KING"<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
My friend is running a 12 bolt with a mini spool and 35's and is Throttle happy! He hasn't had any breakage in alittle over a year...
Mike
<font color=green>"It's like a sore dick deal, You cant beat it!"</font color=green>
<a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
