That looks exactly like the napa one that everyone is selling that I originally posted.https://morrflate.com/
I’ve been looking at this brand for awhile.
I've used the Extreme air unit before. Borrowed it from Larry for a couple of trips. His came in it's own toolbox. It's massive. But it fills tires in no time. Truly a beast. The downside is the size. The toolbox takes up a ton of space.I bookmarked this monster a while back. Seen it on YouTube. 80 amp draw. 8 out of 10 min run time. Probably pretty expensive. http://12-voltair.com/products_12v6cf.php
This one looks really cool! https://www.extremeoutback.com/product/extremeaire-high-output-12-volt-compressor/
Continuous duty but the cfm is pretty low at 100 psi. You also probably don't need 100 psi real often. I would just set it up with a tank for sure.
So the one from Amazon is not the same on that I bought. It is the one that isn't controlled by a computer of sorts. Mine you set the PSI and walk away.
It only took about 10 minutes to fill my tires from 12psi to 30psi. So a 30 minute run time is not an issue.
