OBD1 ALDL to USB Cable used for Data Logging. $20
1227747 ECM has Moates G2 Memory Adapter soldered in place of the OEM chip socket. This allows the use of 28 pin 27SF512 chips. One chip is installed and worked in my 87' K5. Plug and play for stock set up. $25
Cable will fit in a small flat rate box for $8.00, ECM will fit in a Flat Rate Padded Envelope for $8.00
