12Bolt & D44 4:56's Locked, 2" 52's, ORD Disco Kit
HoodRich
Kernersville, NC
GM Dana 44 (pass. drop), Fully rebuilt bearings seals etc., Pass knuckle tapped for hysteer, poison spyder arm, Yukon 4:56 gears, Lock-Right, Warn Premiums, New calipers rotors and pads 2K ago. $700
GM 12 Bolt, Yukon 4:56 gears, 800lb. EATON limited slip, fully rebuilt w/ new wheel cylinders shoes bearings etc. $450
Dana 44/10 Bolt springs plates, $20.00 pair
'87 Chevy 2x4 steering box, (ported for hydro assist) $40.00 sold
'87 Chevy 4x4 steering box, $40.00sold
2" Lift springs (52") Rear, TuffCountryEZ Ride with greasable bushings, $100.00
OffRoadDesign Sway-Bar Dissconnect kit (Front), $50.00
As always if ya don't like to prices make an offer, I've got a good idea what most of its worth but if I'm off PLEASE tell me! All items located in Kernersville, NC or Belews Creek, NC. PM me here or call me at 336-416-2582.
These parts are also posted on NC4x4, & Carolinak5 so best bet is to call if you are interested seriously.
Thanks guys!
steve
do u still have the d44 if so would you do any trading
i got a 1942 ford GPW sme thing as a willys jeep
does have title and does run, needs brakes worked on(could just need bleed havent got around to it trying to get my truck back on road), exhaust needs help needs tight tube headers, and needs differet radiator too small, has a mid 60's 289 with factory trans and t/c, factory axles im pretty sure they have 4.88 gears rear is full float
http://good-times.webshots.com/photo/2881644450101859351sjYgmb
if you still have the 12 bolt ill take it and the dana44 in as trade for jeep
ill trrade you the jeep and $200 for both rear ends
Do you still have the ORD Sway Bar Disconnect Kit?
PM'd ya
