13% for the first week of 2013!
cybrfire
1 ton status
Iowa
Starting tonight at midnight and running for one week.
Take 13% off all online sales.
We're gona let a few sets of tube doors and rock sliders go through at the 13% off price. This is a very limited number. You'll have to take a chance and give me a call to get in on these.
Have a Happy New Year!
Discount code "2013"
that rocks Kert!
I may have to do some more shopping!
Keeping this one at the top for the duration. Get the orders in while you can.
Does this work for the PRP seats too, Kert?
I needs me some seats for the next part of the build.. :D
Sorry, can't do it on PRP seats. I think we already have the lowest price on the planet. Seriously.
Kert,
Any chance you might be interested in building a custom dash?
I know you make the full dash that replaces the factory dashpad, gauge cluster, glove box, etc.
I was originally planning to go that route, but with the brand new dash pad, painted dash, and new HVAC vents, I was thinking about just having someone make me a piece that replaces the factory plastic bezel gauge portion (ie. leaving the dashpad and everything else intact). My issue is I'm using a Dakota Digital display with the gauges pre-mounted and is too wide to fit the flat portion of the factory guage cluster. The factory gauge cluster has pieces with the sides angled. I'm looking for a completely flat piece from edge to edge with a filler piece along the top and bottom to cover the gap to the dashpad (would also have to fit around steering column).
I figure this would be a great alternative for guys wanting to run custom gauge clusters without having to cut out the old dash.
Thoughts?
I'll see if I can get a pic or two up of my current cob job setup to show you what I'm talking about.
I can certainly take a look at it.
All good, Kert. You know I'll be giving you a call soon. I just wish that PRP would send me the fabric samples that I've asked for. :whistle:
How long you been waiting?
Here you go :D
What I'm dealing with and what I was thinking for a setup.
Each could be customized with 3 removable panels (one for guages and blinkers), the lower right for A/C controls and radio (my radio is overhead), and the other for headlight switch (dash mounted wipers if equipped), A/C vent, toggle switches, etc.
Also the dash angles slightly down as you look at it. Being able to angle the guage portion up slightly would be huge.
Just a thought, if you don't think it's worth it, let me know.
Thanks.
Here you go :D
Thanks.
What year is that?
Thanks for helping make the sale a big success guys.
B52's went completely insane. They were the single biggest seller for the duration of the sale. I've been welding them things non stop for 4 days.
Sprinkle in a big helping of comp poly motor mounts and WOW! we've been busy.
Everything from the sale, save a couple first gen pieces have been shipped and right back on top of it.
Thanks again!!
It's a 1980, but I swapped a newer style tilt column in that has wiper delay and hi/low beam on the stalk.
I don't have that version available for measuring and comparisons.
Weren't all dash bezels the same physical dimensions 73-87? Also the portion where the column protrudes through must be similar as you can swap a tilt into a non-tilt and vice versa without swapping out dash bezels.
I would ASSume that all tilt columns shared the same dimensions and all dash bezels external dimensions were the same.
Anyone know if either of those are incorrect statements?
I thought the dash pad and how the bezel fits into it were all together different. Don't know that for sure though.
