1310/1330 u-joint
You can also swap yokes to eliminate having goofy joints, however that *can* cause problems with pinion bearing preload if done incorrectly.
Just to clarify, most 10-bolt yokes were not a 1330 but rather a S44 joint. Very similar size but different.......not sure right off hand if maybe a 1330 joint would work or not? I know the S44 use the internal snaprings while I believe most 1330s use the external snaprings.
I also don't know the p/n listed above is a 1330 to 1310 conversion joint, or possibly the actual part that would work in this application.
Someone please correct me if I'm wrong.
NEAPCO 3-3130 OR SPICER 5-3022X . These are 3R(S44) TO 1310 . They don't call it s44 anymore . And any good parts store can cross it and stock it .
hey Gus, u-joints on Rojas carries them but I dont remember the part number. Give them a Call
