1350 yoke on front ouput 208
thatK30guy
1 ton status
Friend is doing this to his mud runner and the stock size seal won't fit due to the shaft on the yoke being larger than the stock flange type yoke.
Any other seals fit the larger 1350 yoke spline shaft to the 208 front output bore hole? Thought someone might know of another part number to use or cross reference at the parts store.
Not answering your question, but I'm a little confused since my 208 has a flange up front, not a yoke. You have a yoke?
Friend replaced the flange for the yoke since the angle is low enough to accept one. Its his mud runner and his 565 puts out gobs of horses so trying to eliminate the cv joint.
I know, I know, I've tried to tell him to ditch the 208 but its weight savings and he has spares for parts, etc.
Nobody has run a 1350 yoke on the front output of a 208?
If you go to the SKF website, you can enter ID or OD needed, and it will give a list of seals.
A good bearing store should be able to look it up by size.
Martin
