1350 yoke
They are 1350 from the factory. If you already knew that and have a damaged one you're trying to replace then i think i do have one at work. I'll check tomorrow and check back here to see what you've said.
I did know that, and i do have a damaged one. The little nub that holds the cap from sliding is sheared off.
A quick fix would be to weld a tit on the strap till you get a new yoke, or maybe you already thought of that.
Jimbo
got one im not using, 35$ shipped
gmcjimmy4x4 said:
how much would you like for it shipped to sacramento 95842. It is a 1350 for a 14 bolt ff, right?
Hey I should have one here $25.
You will probably have to come to pick it up though. :D
Bring yours if you can to make sure I get you the right one. :confused:
